Chat Area => General Discussion Area => Topic started by: TheBoy on 19 September 2006, 18:59:33
Title: Cruise Control - ECU pre-enabled
Post by: TheBoy on 19 September 2006, 18:59:33
OK, for those with drive by wire Omegas, and WITHOUT cruise fitted before you got it, was cruise enabled in ECU (so only had to add stalk...
Title: Re: Cruise Control - ECU pre-enabled
Post by: Martin_1962 on 19 September 2006, 20:21:52
How do I see the results (haven't tried yet)
Post by: Del Boy on 19 September 2006, 20:26:28
Have a 3.0 Mv6 so can't vote ;D
Post by: Elite Pete on 19 September 2006, 20:31:49
Ive got the mini facelift Elite so I cant either. One good thing though, mine came with cruise as standard [smiley=thumbsup.gif]
Post by: Del Boy on 19 September 2006, 20:33:47
Lucky u  ;D
Post by: Elite Pete on 19 September 2006, 20:37:23
There should be a poll to see who uses there cruise, I find the roads are to busy.
Post by: Del Boy on 19 September 2006, 20:39:28
True they are nowadays i dont use it in my scorpio
Post by: Timbuk on 19 September 2006, 20:39:52
Whats cruise [smiley=cry.gif]
Post by: CaptainZok on 19 September 2006, 20:52:12
Ive got the cheapo cruise conversion in mine.
Brick on the gas pedal. ;D
Just like the hand throttle on a crane wagon I used to drive, diary and a piece of wood wedged on the gas pedal to run the pto.
Post by: tunnie on 19 September 2006, 21:29:20
2.2 Petrol Manual, not enabled.
But now is thanks to Jaime!  :) - Very usefull
Post by: TheBoy on 19 September 2006, 21:47:01
I only put the drive by wire cars on poll, as non drive by wires do not need enabling (just add the bits and it works)
Post by: TheBoy on 19 September 2006, 21:47:46
As will you Dad's...  ;)
Post by: Del Boy on 19 September 2006, 21:51:41
Where u dont have to use your feet
Post by: TheBoy on 19 September 2006, 21:53:50
vote, then you see.
Post by: STMO123 on 19 September 2006, 22:18:25
I think that cruise spoils the driving experience ::)
Post by: TheBoy on 19 September 2006, 22:21:43
Sort of agree, but sometimes I don''t want to drive, I just want easy journey. Also use in 30mph zones to help keep speed down...
Post by: Auto Addict on 19 September 2006, 22:31:38
I've had 2 cars with cruise, a Senator and a Carlton Gsi, don't miss cruise at all.
Post by: Timbuk on 19 September 2006, 22:35:56
I've got cruise on the Volvo and i end up using it just for the hell of it
Post by: Gwilym on 19 September 2006, 22:52:42
Now I am a bit confused.
Is my 2000 W reg MV6 enabled. ie can I just get a different indicator stalk with cruise buttons and plug it in?
Post by: Bo Bo on 20 September 2006, 07:07:29
Can't vote either
Post by: TheBoy on 20 September 2006, 10:25:43
If its a 3.0l then you need the actuator, cable, stalk, brake switch and clutch switch if manual...
Post by: Hillper on 20 September 2006, 10:53:34
I don't see why the MV6 couldn't be enabled.
I think there's an urban myth about this pre-enabled lark.  Why would some be pre-enabled?
I think it's because the diesels are ALL pre-enabled (aren't they?) and after adding the effects of Chineese whispers, the rumour has spread.
Edit.  Of course.  The 3.0 is not FBW.  The 2.6 and 3.2 is.
Post by: bob.dent on 20 September 2006, 11:24:42
Mine sure as hell hasn't got it - used to work on a cruise ship once though.....does that count? ;)
I don't actually know if my cars rigged for cruise control or not - how would I find out?
Post by: TheBoy on 20 September 2006, 11:35:02
Being a non DBW, it has no concept of being enabled. Add all the bits, and it will work.
Post by: Auto Addict on 20 September 2006, 11:37:52
I put mine into sports mode to hold it in a lower gear, especially if going downhill in a 30 with speed cameras about.
Post by: Auto Addict on 20 September 2006, 11:42:36
Anyway, I've voted for the wrong thing, so that messes up your stats., didn't mean to, sorry. :(
Post by: TheBoy on 20 September 2006, 11:52:25
AA - your vote removed so you can do it properly this time ;)
Post by: Auto Addict on 20 September 2006, 11:55:55
Might not want to now, so there.......anyway, I'm not sure what to vote for as I'm not bothered about having cruise.
Am I bovvered?
Post by: Auto Addict on 20 September 2006, 11:58:18
OK, I've voted again now [smiley=thumbsup.gif]
Post by: bob.dent on 20 September 2006, 12:24:28
DBW?????.....huh :-?
Post by: TheBoy on 20 September 2006, 12:26:52
Sorry, Drive By Wire...
Post by: bob.dent on 20 September 2006, 13:26:13
Ah, gotcha. Don't think I'd bother fitting cruise though because I doubt if I'd use it much. Also, at some point I'd like to chop my current Omega in for a later higher spec model which will probably include cruise, just need to win a few quid on the lottery first! :D
Post by: Gwilym on 20 September 2006, 18:45:51
it is auto but still sounds too difficult to bother with
Post by: The Barge Captain on 20 September 2006, 21:47:24
OK. I've got cruise on my new Omega, but just where are you ment to put your foot? It's not like the clutch where there is a space for it, do you just put it on the floor further back so you can steer with your right knee whilst making a cup of tea using those nice electric heated tea mugs avalible from all second rate service stations?
Post by: Del Boy on 20 September 2006, 21:48:39
 ;D
Post by: SMS01 on 21 September 2006, 14:49:24
Have got cruise (ps sorry - posted on wrong answer - FBW didn't click when I first read it!), use it all the time, almost every day even if just doing local runs. tend to find it is a bit cheaper on fuel for constant speeds and obviously protects against speed cameras.
As for taking the fun out of it - rubbish, you only have to press the throttle down if you want to bring the fun back. If you want the full driving experience then don't use it, but if you feel like being lazy, you can just let the cruise deal with it. Only improvement I could wish for was an automatic with cruise but having a manual, you still have to do something every now and again.
Post by: Hillper on 21 September 2006, 21:32:42
You place the now redundant right foot alongside the left foot inside the big tartan slipper, light your pipe and relax!
Post by: CaptainZok on 21 September 2006, 21:46:05
Ahh the Hillper School of Motoring still going strong I see.
Post by: Taxi_Driver on 23 September 2006, 19:54:37
Am I bovvered?
Ive got cruise......go on AA you know you want it  ;)
I used it today A303....nice bit of road mostly dual carriageway  :D
