Omega Help Area => Omega General Help => Topic started by: LFF64 on 28 February 2009, 12:42:24
I have just noticed the tahco is not working , problem is I am not syre when it stopped .
I have just fitted the sat nav to my car so something may have happened while doing that :-[ but I have also had the dash display out at the same sort of time .
I have pulled the dash display out and reseated it and it made no difference .
When I start the car I can see a very slight defection on the needle .
Other than the needle not moving what other problems may this be causing the car runs fine :y
We can stick tech2 on it which will show if its a tacho failure or a poor connection between car and dash
Any one have a decent wiring diagram please I am not sure which wire is the tacho feed looking in the haynes manual :-/
Book of lies if you have one...
I have one but its not clear to me anyway which wire it is :-[
Pop it over at some point, we can take a look. If Tech2 is non conclusive, can always try a dash from either of mine (both are electrically compatible with yours)
Thanks to The Boy the tahco is now working again :y it was something really stupid too ME :-[ the connector that the display pushes in to had distorted slightly and was not making contact a bit of bending about and all working again ::)
Thanks again Jaime :y
No probs :y
Did the MID get it's time back before you got home?
No not unless it was 0100 :D Sent you a pm I did have another little problem ;)
PM seen, just pondering on it...
i keep coming back to main connector in passenger kick panel. may be worth checking its hurry seated, and no pins pushed up.
Every thing seems ok today :-X I suspect it may have been the battry a bit low on the way home . So thanks again :y
