Omega Help Area => Omega General Help => Topic started by: mick-1975 on 06 March 2009, 19:17:29
Title: update on non starter please help!!!!
Post by: mick-1975 on 06 March 2009, 19:17:29
please help right then , i have  changed the starter as seems to be knocking from there ,  checked the earth straps ,
  i have tried to stsrt it but still no look and there is still a knocking noise ,
seems only once complete turn of the engine ,
 did not do it when i used a spanner to check the timing ,
 i need all your help please as im not really happy at the moment   :'(
 thanks   :y
Title: Re: update on non starter please help!!!!
Post by: Agemo on 06 March 2009, 20:08:46
Can you hear anything, when you turn the engine over with a spanner?  Have you done a paperclip test?  :-/
Post by: mick-1975 on 06 March 2009, 20:10:53
 no noise when use  of the spanner , i did a paper clip test the other day and code 15 came up , which i got told coolant temp,
no other codes ,  :y
 looks like i got every one stumped  :-/
Post by: Agemo on 06 March 2009, 20:14:18
there will be someone here who knows, you just have to wait until they are online. Best of luck.  :y
Post by: mick-1975 on 06 March 2009, 20:15:25
  thanks i need that help big time as im stumped !!!! :y
Post by: VX1 on 06 March 2009, 20:29:11
Have you connected the cam sensor and crank sensor?
Just a thought.
Paul :y
Post by: mick-1975 on 06 March 2009, 20:31:59
Just a thought.
Paul :y
yes everything connected, going to double check tomorrow,
and for that noise i have no idea ?  :(
Post by: VX1 on 06 March 2009, 20:43:45
Could be the solenoid on the starter thats dodgy? or knackered battery.
Paul :y
Post by: mick-1975 on 06 March 2009, 20:46:05
Paul :y
  i put the battery of the mig i use to try and still no luck !!
Post by: VX1 on 06 March 2009, 21:32:51
Leads on the correct way round?
Paul :y
Post by: mick-1975 on 06 March 2009, 21:36:16
Paul :y
  yes they were ,  :'(
Post by: VX1 on 06 March 2009, 21:43:28
Have you checked all 5 (I think) earth straps? I know you said you checked but how many of them? Is the connection to the body free from corrosion? Just going through the book of lies to eliminate possible causes.
Paul  :y
Post by: Marks DTM Calib on 06 March 2009, 22:07:06
Did you at any point turn the crank anti clockwise?
Post by: mick-1975 on 07 March 2009, 13:27:22
   i left the crank in the same place , , thanks  :y
 what are the chances of the fly wheel be broke , (tooth broken )
