Omega Help Area => Omega General Help => Topic started by: gstylebaby on 06 March 2009, 13:45:26
Title: Steering wheel......AAAAhhhhh
Post by: gstylebaby on 06 March 2009, 13:45:26
Bought a carbon steering wheel ages ago and have tried to fit twice now first time found the airbag wont fit so sorted that and got hold of one tried again today and found the blood squib wont fit looks like I need a different one (sounds about right) but looks like it fits different as well so need to get what looks to be a white plastic bracket that it fits to.
I am thinking it would have been easier to change the whole bloody rack and then I could get the adjustable one fitted.
Has anyone else had this problem???????
Title: Re: Steering wheel......AAAAhhhhh
Post by: markey mark on 06 March 2009, 13:47:42
no i have had one fitted on all mine and just fitted one on guys car no probs at all bud !  :-?
Post by: Jimbob on 06 March 2009, 13:51:20
I've got a steering wheel down my pants......
It's driving me nuts  ;D ;D ;D
Post by: gstylebaby on 06 March 2009, 13:55:05
You fitted the wheel or the steering column mate.....
Post by: gstylebaby on 06 March 2009, 13:55:41
Trust you jim.... :D :D
Post by: markey mark on 06 March 2009, 13:56:03
just the wheel bud
Post by: gstylebaby on 06 March 2009, 13:59:59
just the wheel bud
How hard is it to fit a whole column mate any ideas.....Fancy having the ajustible one...
Post by: Andy B on 06 March 2009, 14:08:14
just the wheel bud
Can't be too difficult, picture in Haynes looks to show a split collar/pinch bolt set up  :-/ . You could always opps up it up try it in the scrap yard first as a practice  ::) I haven't been to Pimhole for a while (apart from my facelift Elite alloys), but there's bound to be one there.
Post by: gstylebaby on 06 March 2009, 14:18:35
just the wheel bud
Was thinking the same thats were i got the airbag from...i hope they still have the same car i got that off...Gonna go on sunday and see whats what.
Thanks andy what do your new wheels look like then and are you happy with them mate? :y :y
Post by: markey mark on 06 March 2009, 14:22:49
not too bad two 13mm bolts at top and a 13mm pinchbolt at bottom ! oh and a pita shear bolt at top iirc  :y
Post by: Andy B on 06 March 2009, 14:33:12
They look good,i d fancied some for a while. I'll be happier with some proper rubber on them, 2 Events & 2 A N Others  :-? There's a definite difference in ride though between 16" & 17" rims, we could do with les potholes around here. :y :y :y
Post by: Andy B on 06 March 2009, 14:35:47
The transpoder/ignition bit doesn't look too easy to swap though. I had a quick look for someone here ( :-[ can't now remember) while I photo'd mine to compare against his butchered ignition.
Post by: gstylebaby on 06 March 2009, 14:47:44
Did'ent think about that bit mite just have to stick with swapping the bits i need over and hope that does it.
Glad to hear you like them and i know what you mean about pot hole's same round here i try to do my best getting round them but must look like i've had a few to the people behind. ;D ;D ;D
Post by: gstylebaby on 06 March 2009, 14:49:21
Nice one mark but forgot about the transpoder/ignition bit so may not be a good idea after all dam it.....
Post by: markey mark on 06 March 2009, 15:04:51
thats the easy bit bud  :y :y
Post by: Marks DTM Calib on 06 March 2009, 15:28:02
Easy enough to do, and there is info in the maintenance section.
I think the adjustable steering column is a must have.
Post by: TheBoy on 06 March 2009, 17:21:12
Certainly makes getting instrument panel in and out a damn sight easier, even if you don't need to adjust column normally ;D
Post by: gstylebaby on 10 March 2009, 02:06:53
Well went to the brakers got new squib and plastic bracket and the squib has no conector on and had to gut the wires just hope they are the same on mine so i can split and solder the new squib to it but will have to check cause all the set up  looks different from mine so expect me to back on with pics to try and sort this once and for all.  I really want this to go on but not looking to good at the mo.
Did'ent get the full steering rack as it was non-ajustable same as what i already have.  Would like to have that option though.
Post by: gstylebaby on 10 March 2009, 02:08:08
Got to agree with you on that mate it would make it easier.
