Omega Help Area => Omega General Help => Topic started by: Russell on 28 May 2008, 21:10:24
Title: Idle Jet Filter
Post by: Russell on 28 May 2008, 21:10:24
Hi out there,
Is it possible to fit some kind of filter to the small breather hose that connects the idle jet to the cam cover.
I( am getting fed up with continually cleaning it!
Respects
Russell
Title: Re: Idle Jet Filter
Post by: tunnie on 28 May 2008, 21:12:31
I assume you mean the Idle Control Valve?
What engine do you have?
It should only need cleaning once a year really.... do you do lots of short runs? How often do you change the oil?
Post by: Dazzler on 28 May 2008, 21:12:53
You will only end up cleaning the filter even more than you do now :-/
Post by: Russell on 28 May 2008, 21:20:38
Hi Tunnie,
Engine is 2.0 16v auto. Use car for work approx. 170 mile round trip every day.
Car has had lpg conversion which is fantastic. Last cleaned ICV approx 2 month ago, but since then have had a new (breaker) engine fitted 2 weeks ago. So has had fresh oil/filter change.
I keep oil topped up regularly as handbook states engine uses approx 1 litre oil every 1000 miles?
Do I need to do a regular oil change based on my mileage?
Regards
Russell
Post by: tunnie on 28 May 2008, 21:27:09
i do low miles so i change it every 3 months.
On trade club you can get GM oil filters for £1 and 5L oil works out at £8!
So dirt cheap, make sure you clean the whole breather system and throttle body.
I gave mine a damn good clean last year, poped it off a few weeks ago, still really clean not much dirt on it.
You do a lot of miles, i would be changing it every month!
Post by: Lazydocker on 29 May 2008, 01:53:30
Definitely look at no more than 6 weeks between changes. I know it seems a bit extreme as the lpg means the oil stays cleaner but you must do closer to 1k miles/week by the time you've done the social stuff on top of the commute! :o :o :o Keep on top of the oil changes and you'll find you get fewer problems!
Post by: Russell on 17 June 2008, 22:23:22
Hi All,
Here's an update on my IACV.
Removed IACV and throttle body, gave both a good clean.
Used a pull through to clean larger breather hose (squeaky now).
Smaller hose to idle jet was completely clogged, so replaced it.
Not disregarding advice about an inline filter, but thought it would'nt hurt to try it out.
Placed small plastic inline fuel filter in the small hose.
Have been running car for two weeks now with no problems. As filter is clear can inspect for contamination. So far so good.
Will post a picture tomorrow and keep you all updated.
Regards
Russell :-) :yhttp://images.omegaowners.com/forum/yabbfiles22/Templates/Forum/default/thumbsup.gif
Post by: Kevin Wood on 17 June 2008, 22:57:29
The air that flows through the IACV has already been through the main air filter, so it's as clean as it's going to get.
Post by: Russell on 18 June 2008, 05:34:37
Kevin,
I am talking about the idle jet which is situated under the butterfly in the throttle body and is notorious for becoming blocked eventually as the small hose is connected to the rocker cover.
Russell
Post by: Kevin Wood on 18 June 2008, 07:21:31
Kevin,
Russell
Ahh, OK. Appologies. I know the beastie. In that case, it's down to keeping the oil clean with regular changes, I guess.
Post by: BruceT on 18 June 2008, 08:00:58
When I cleaned my breathers and Throttle body, the small breather was pretty much clogged up all the way.
Think ill replace it!
Post by: ians on 18 June 2008, 18:14:22
they often always are
Post by: Russell on 19 June 2008, 05:47:05
Hi All,
Here's the photo I promised yesterday:
(http://i262.photobucket.com/albums/ii91/rpro59/100_0061.jpg)
Regards
Russell
Post by: BruceT on 19 June 2008, 07:50:34
Good idea, think ill do something similar when I get a new pipe. Although
Post by: Russell on 14 March 2009, 10:47:47
Hi All,
Just an update on the small inline filter. This was installed for about a year and was just showing signs of oil contamination with rpm jumpy at idle. I have replaced the filter and all is back to normal (After cleaning the first piece of hose from rocker box to filter.
Russell
Post by: Abiton on 14 March 2009, 13:27:03
I reckon this is a damn good idea, and I shall be doing the same.
 :y Good work Russell  :)
