		Omega Help Area => Omega General Help => Topic started by: VX1 on 14 March 2009, 09:36:19
				Andy, there is a how to in the maintenance section on removing the lcd display.
 Paul :y
				http://www.omegaowners.com/forum/YaBB.pl?num=1152745540
				Cheers guys..... pretty straight forward  :y :y
				Climate control panel needs dismantling to renew illumination. Bugger that up and it`s megabucks  :o
				Time to renew all the dim looking bulbs in the dash and center console today with upgraded blue led's (not Cheap jobbies by the way)
 the dashboard ones are no problem but has anyone any advice on removal of the center console to renew the bulbs behind the LCD panel for the heaters.....
 oh dear.....
				Changed back to original as the blue is pretty poor to be honest, looks great on the speedo rev counter etc but the rest is poor poor poor, the lad down the road has brought the blue bulbs so no loss.
 DONT DO THE BLUE BULB THING.........
 :y :y :y
 oh dear.....
 Ditto
				Blue LED's Dont work with the lightswitch dimmer system! you will be getting through lightswitches like hot cakes!
 i have them and have had to rewire the led'd to a switch on a constant 12v as the lightswitch supplies a reduced voltage and LED's dont seem to like it so blow the light switch up
 also you cant read the dials in the day and after a while they get annoying
 but at £15 a pop from scrappies you will be needing lots of light switches :y
 if you wire them to a direct feed then you must fuse that feed and the light switch needs some minor modification to disable the dimming functions
 also i had great trouble in getting the climate bulbs to actually work!
				sad sad sad sad sad lol
 just my opinion
				Novelty factor lasts about 24hrs, then you realise you can't see Jack Sh1t  !!!!!
 :y :y :y
 Agreed......
				 unusually reserved from TB I thought. :-)
