Omega Help Area => Omega General Help => Topic started by: rikki_essex on 20 March 2009, 06:55:35
right a couple of things. the engine was fine one night then i drove it the next moring and was mis fireing quite badly so i took it into the garage last night and they done a dio on it.witch bought up the same faults i already knew 0300 and 0305. Which they told me was random mis fire and misfire on cylinder 5. They have now said they will price it up but they are going to change the spark plugs and both coil pack. They think it will be about £300. Firstly does that sound about right and secondly the said they will have to strip it right down to get to the coil packs is this right????
To start with I would never let a garage change my plugs and coil pack as that is a job easily accomplished by even a novice, maybe referring to the guides on this forum. ::) ::) ::) ;) To me, £300 is daylight robbery, but I suppose if you really cannot do it yourself, then you pay it! - Unless of course you can find someone on here, close to you, who could do it for beer money + parts! :D ;)
Secondly though is I wonder why this problem has come on so suddenly. It could be due to the infamous cam cover gaskets leaking and allowing oil to get into your plug wells, thus they will end up overheating and misfiring. If this is the case, before the plug and coil pack are replaced, check those plug wells as that, along with the cam cover gaskets, could be the real cause of your problem! :D ;)
Firstly, there is no indication that it's anything other than cylinder 5 so why are they changing both coil packs?
I agree with Lizzie, Check for oil in the plug wells first, then condition of plugs themselves. Only after that should expensive items like the coil packs be suspected.
They have quoted without doing a thorough diagnosis.
well i think i will have ago myself then but the way they was saying its a big job getting the coil pack off and as a precation change all the plugs and both coil packs. Do you know what side cylinder number 5 is then??
No 5 is the driver side rear cylinder
And the coil pack can be removed in about 5 minutes ::)
brilliant ive printed off the guide how to change the spark plugs but if i do need change the coil pack is it just a plug in?
Yes plug straight in. the job is awkward, but there is nothing difficult about it. :y
yep and available here.
You need to remove the coil packs to get at the plugs so inspect them.....check for signs of corrosion and split plastic.
They are available here if required:
http://search.stores.ebay.co.uk/VAUXHALL-PARTS-WAREHOUSE_omega-coil_W0QQfciZQ2d1QQfclZ3QQfsnZVAUXHALLQ20PARTSQ20WAREHOUSEQQfsooZ1QQfsopZ1QQfsubZ14QQsaselZ169071634QQsofpZ0
just tracked down a coil pack 65+vat and only in romford so going to pick them up in the morning so hopefully should be done by the 1 tomorrow. :y :y
Dont forget the 2.6 and 3.2 have 2 coil packs, one for each bank.
I assume you have looked at them and confirmed they are the issue?
yes mate run the chassis number through vx and confirmed with the other place aswel so hope fully it will be the right one. :y
