Chat Area => General Discussion Area => Topic started by: VXL V6 on 17 November 2007, 17:48:42
I just wanted to say a public thanks to Sassanach for changing the transmission fluid on my car today, got this done as a precaution really as the fluid was the original (62K) and it was time for a change. The gearchange is a lot smoother as a result.
Anyway, a very knowledgeable chap who I reckon could dismantle and reassemble an autobox with his eyes closed! So thank you for sorting it out and showing me how it's done. I reckon I could even attempt it myself now i've seen it done, however, having the car 6ft up in the air is a definate advantage I don't have the luxury of here!!!!
Cheers Mate :y
PS. Definately inspired by the neat LPG install on the Saloon........ got me thinking now!!!!
Cheers Mate :y
Yup, he certainly does know his autoboxes. And the rest of the car as well :)
I really must do the ATF in the MV6, but I daren't remove the sump as I'm dreading finding bits of washer!
Yep, when dropping that front sump you hold your breath!!!
Something i keep thinking about getting done......nearly 110k miles on original atf.....and used as a taxi for the last 70k.....it must be a bit knackered by now the atf.
But my local garage i use......doesnt want to touch it.....ie boss reckons if it aint broke.....dont do anything......i see some logic in this.....as i have seen a few posts when atf has been changed the g/b either develops probs or fails completely :-/
Interested to hear Sassanach's opinion on this??
BTW theres nothing wrong with my g/b.
it wasn,t that long ago when changing the atf was standard servicing and on a lot of cars it still is.btw if it aint broke don,t fix it is the way it should be then why do you change your engine oil? :)
You know the answer Dave.... jack, stands, bowl, and socket set ;)
it wasn,t that long ago when changing the atf was standard servicing and on a lot of cars it still is.btw if it aint broke don,t fix it is the way it should bthen why do you change your engine oil?e :)
Ditto for clutch/brake fluid, but a lot of manufacturers are starting to use sealed units.
Is there anything that doesnt need to be changed on a regular basis?
apart from the Owner ;)
......and his wife ;D
Well i think that certain opinions could vary there ::)
There really are some Great people on here who at the drop of a hat are willing to go and help others.
Proud to be a member on here I really am. :)
I will second that Daz :y :y
I'll third it!
Yah, yer big Jessies :P
OI
who you calling big Fatty ;) ;)
