Omega Help Area => Omega General Help => Topic started by: damon80 on 26 March 2009, 10:24:28
Title: Error Code 0336
Post by: damon80 on 26 March 2009, 10:24:28
Hi Folks,
Just been having difficulties starting my Miggy - it did get going eventually, after quite a bit of cranking...
Which makes me think the crankshaft position sensor is goosed.  Done the pedal trick, and it's showing "0336" - but error code for CPS is "0335"  :-?
How difficult is it to change?
Title: Re: Error Code 0336
Post by: RobG on 26 March 2009, 11:44:44
Have a gander here http://www.omegaowners.com/forum/YaBB.pl?num=1174321688 :y
Post by: mantagte on 26 March 2009, 12:03:30
0336 is crankshaft position sensor range performance problem
check wiring and remove cps make sure it is clean
Post by: damon80 on 26 March 2009, 15:01:07
Hmmm, so I might not need to replace it after all??
What's the best way of cleaning the sensor?
Post by: mantagte on 26 March 2009, 22:37:09
bit of rag with some wd40 works
Post by: feeutfo on 26 March 2009, 23:31:13
just change the bugger. Afaik its only the wiring that ever fails due to production line convenience its fitted with the cable to near the exhaust, it will fry the wire eventually, add in some oil from cam covers and any coolent leaks and it all adds up to a failure of the insulation and the cable breaks. Not worth trying to fix it, bin it and route the cable away from the exhaust. Its to important a part to mess with. Hth
