Omega Help Area => Omega General Help => Topic started by: 4huftys on 01 April 2009, 11:17:26
Title: Fuel Trim
Post by: 4huftys on 01 April 2009, 11:17:26
Keep getting error codes 0170 and 0173 fuel trim bank 1 and 2 can anyone help with this please
cheers Dave
Title: Re: Fuel Trim
Post by: kcl on 01 April 2009, 11:21:58
MAF related, assume you have 2,6 or 3,2 engine... Do a search, enogh of threads about these codes
Post by: 4huftys on 01 April 2009, 11:26:24
Yes forgot to say 2.6 engine
Post by: Proz on 01 April 2009, 11:28:58
I had this on my 2.2 and was cured by new genuine Maf  :y
Post by: Kevin Wood on 01 April 2009, 12:08:09
MAF is a possibility, and we have seen a couple of failures on DBW engines.
Could also be an air leak in the ducting, so inspect that carefully for splits and make sure all the joints are sound. Could also be any fuelling issue that affects both banks such as clogged fuel filter, low fuel pressure, coolant temperature sensor, etc.
Are you able to get it to a fault code reader that will show live data? Would be interesting to see what the MAF is reading at idle when fully warmed up, and also at a fast idle (2500 RPM).
MAFs are expensive so it's worth a bit of diagnostics just to confirm.
EDIT: While you've got a code reader on it check the coolant and air temperatures are plausible and have a look at the fuel trim values for both banks. See if they have both moved in the same direction.
Post by: webby23 on 02 April 2009, 22:13:25
Exactly the same engine and problem as me too.
Solved with replacement MAF sensor, EML light not been on since.
