Omega Help Area => Omega General Help => Topic started by: Ziad on 09 April 2009, 15:42:25
I have my sunroof open and now i cannot close it. Turning the knob does not do anything. I have checked the fusebox under the steering column, and all the fuses are OK. I have then checked the fusebox in the engine compartment, and found that one fuse is burnt (when i say burnt, i mean, it's literally melted!). It's a 30A fuse located in the upper section of the fusebox at the extreme left.
What can i do to close the sunroof? Is there a way to manually do it???
On the panel with the switch you use to close the roof there is a U shaped plastic cover! remove this by sliding it!
you will find the manual winding mech in there! use a large flat screwdriver to turn it and the roof will close ;)
Hope this helps :)
Thanks a lot mate. I got it closed ... and on time too! It just rained! lol :)
[http://i717.photobucket.com/albums/ww173/ziad11/front.jpg]
Hope this helps :)
