Omega Help Area => Omega General Help => Topic started by: caran10 on 19 March 2009, 22:30:37
Title: 2.6 retro cruise
Post by: caran10 on 19 March 2009, 22:30:37
Can i fit a cruise control to my 2002 2.6 manual if so what do i need and how do i fit it
thanx
Title: Re: 2.6 retro cruise
Post by: Kevin Wood on 19 March 2009, 22:33:13
You'll need the indicator stalk with the buttons on, probably a clutch switch, and it needs to be enabled using a Tech 2.
EDIT: see http://theboy.omegaowners.com/
Post by: nick v6 on 20 March 2009, 07:36:48
pm loo knee he might have one
i think there is a connector under the bonnet on the passenger side
if you aint got that connector you can't have cruise control
Post by: jonathanh on 20 March 2009, 07:43:04
no - the 2.6 is DBW which means that the cruise software in the ECU drives the servo motor on the throttle body.  On the 2.5/3.0 there is no servo but a traditional throttle cable.  This set up needs an actuator and the multiplug to drive the actuator.
Post by: TheBoy on 20 March 2009, 08:26:58
To clarify some of the misdirection on this thread, on 2.6, you **may** need clutch switch (check if one already fitted, a 4 wire cruise stalk, and a quick program with a (real) Tech2.
for the programming, as Kevin Wood says, http://theboy.omegaowners.com :y
Post by: Marks DTM Calib on 20 March 2009, 08:44:03
And as I work in Coventry then Tech2 access should be reasonably easy to arrange
Post by: caran10 on 21 March 2009, 20:06:13
how can i tell if clutch switch is already fitted
Post by: caran10 on 11 April 2009, 08:55:45
HI JUST CHECKED and cant see clutch switch on the pedal ,( is it like the brake light switch ) can i fit one is the wiring there as standard
caran10
Post by: caran10 on 11 April 2009, 08:57:56
no i havent got a clutch switch  can i fit one
Post by: TheBoy on 11 April 2009, 10:24:37
Wiring should be there - normally taped up to part of loom.
Post by: Marks DTM Calib on 11 April 2009, 10:27:00
For some reason the clutch switches now cost 20+quid!
I have a stalk available (only 20K miles old)
Post by: TheBoy on 11 April 2009, 10:33:22
The Omega ones always were stupidly expensive - seem to recall a few years ago that they were £15 + VAT....
Post by: caran10 on 11 April 2009, 10:40:41
IF I GET A CLUTCH SWITCH how do ifit it to the clutch pedal
