Omega Help Area => Omega General Help => Topic started by: Tresvant on 12 April 2009, 12:05:23
Title: Any quick tips??
Post by: Tresvant on 12 April 2009, 12:05:23
Just trying to fit my replacement HBV. Spent the last half hour trying to get pipes off without sucess. I know on here the guide says it easy to access but i am really struggling to get my grips round the fastner things. Anyone got any tips to help??
cheers
Steve
Title: Re: Any quick tips??
Post by: Lizzie_Zoom on 12 April 2009, 12:10:12
cheers
Steve
I use an adjustable jaw wrench for that job ;)
Post by: chrisdb on 12 April 2009, 12:11:11
If you're really stuck you can get much better access by removing the wiper scuttle. If you're going to do a lot of work in future there is a special tool for these clips - have a couple and one has a long flexible end.
Post by: Tresvant on 12 April 2009, 12:16:01
Cheers, the scuttle is off just cant seem to get the bloody clips off. Will keep trying, out of interest whats the special tool called - not that there is anywhere open today i can get one from.
will try the adjustable wrench idea thanks :y
Post by: Lazydocker on 12 April 2009, 12:56:08
Mole Grips ::) ::) ;D ;D
Seriously though... There is a Hose Clamp tool but TBH mole grips work just as well, if not better, on smaller bore pipes :y :y :y
Post by: TheBoy on 12 April 2009, 13:09:27
Aye, mole grips are the tool of choice for me.
Do NOT be tempted to replace with jubilee clips on reassembly.
Post by: dbug on 12 April 2009, 15:09:30
Third that - "small" mole grips ideal.
Post by: Lizzie_Zoom on 12 April 2009, 15:12:51
That's interesting TB, as I did after it was stated on here that fitting them was not a problem! :o :o :o :o
They were supplied by my Vx dealer and seem to be available for this pipe work rather than the crimp type. I have encountered no problem since (5k miles ago) ;)
Post by: chrisdb on 12 April 2009, 16:04:12
This is the tool I have: http://premiertools.co.uk/products/Remote_Action_Hose_Clip_Tool.htm. As said on here, the mole grips are good, but I've had a couple of occasions where the clip was positioned in a way that it was not possible to get any pliers or grips in the right position. Then this tool was brilliant because you can bend it into tight spaces, and it has a ratchet action which locks. Quite often the clip needs some jiggling to free it from the hose and this tool grips so tight that there's no danger of it slipping off like with mole grips.  :y
Post by: kingplym on 12 April 2009, 16:14:43
out of interest whats the big no no with jubilee clips?
Post by: TheBoy on 12 April 2009, 16:58:20
As well as being quick (thus cheaper) in manufacturing process, the spring loaded ones also apply an even pressure, no matter how hot/cold. Jubilee clips are a constant size, easily overtightened, and don't allow for the small amount of expansion/contraction as the pipes heat/ccol. Generally, jubilee clips shouldn't be used on plastic pipes, as they tend to crack.
Post by: Tresvant on 12 April 2009, 19:07:10
Could not get them off at all got fed up and sacked it off, will have to put up with heaters on for a few more days until i fancy another go. Still managed to get an oil and filter change done so not a total waste of a day.
Thanks for all the info
Steve :y
Post by: chrisdb on 12 April 2009, 19:47:30
Steve :y
Would you like some help? I'm not too far from Nottingham and have time this week.
Post by: Tresvant on 13 April 2009, 10:16:01
thanks for the offer chris but i still not been able to repay you the favour for helping me with my cam covers last year! And sadly i have not got anytime off this week, but thanks again for the offer.
cheers
Steve
Post by: tunnie on 13 April 2009, 11:09:16
bit of WD40 on them usually helps them slide off a bit easier
Post by: Tresvant on 14 April 2009, 10:37:43
Tried again late yesterday, still not managed to get them off no matter how hard i try, used shed loads of wd40 and although i manged to loosen the clips of 2 of them the bloody pipes would not budge. In my frustration whilst stomping around i stood on my scuttle thingy and snapped a corner of it  >:(. With a bit of luck i can get those 2 off but how i the hell i can get the one from the passenger side off beats me. I am ok to go disconnecting other pipes etc in that area so i can get better access as long as i remember where they go?
Shall wait until the skin has grown back on my knuckles until i try again.  :(
thanks
Steve
Post by: ians on 14 April 2009, 12:22:16
If its any consolation, many of us have been there before contributing to the swear box..
I use small mole grips for ease of access.
Might be easier if you do it when the engine is warm.  You can unclip it from the bracket which makes things easier once you have removed the pipes on the drivers side - it moves around quite a bit.
