Omega Help Area => Omega General Help => Topic started by: OmegaGav on 15 April 2009, 13:16:17
Title: nut tightness (water pump)
Post by: OmegaGav on 15 April 2009, 13:16:17
Hi just a quickie  :P does anyone know what nm the bolts should be tightened to, when fitting my new water pump we think it should be 25nm but would like to check just in case  :-/ :-/ :y :y
Thanks !
Title: Re: nut tightness (water pump)
Post by: Marks DTM Calib on 15 April 2009, 13:34:46
25Nm for the pump to block bolts (V6), apply a smear of grease to teh rubber O ring and around the edge of the pump body plus clean the mating surface with wet and dry.
The pulley bolts are 12Nm with a dab of loctite
Post by: OmegaGav on 15 April 2009, 14:09:08
Thanks Marks now i see why you have lots of stars  :) :) :) :y :y
