Omega Help Area => Omega General Help => Topic started by: Martin_1962 on 16 April 2009, 15:04:00
Title: 3.0 cams identification
Post by: Martin_1962 on 16 April 2009, 15:04:00
How do I tell which one is which?
Title: Re: 3.0 cams identification
Post by: Richard148 on 16 April 2009, 15:36:51
(http://i10.photobucket.com/albums/a103/MartynJones/V6/v6Cams.jpg)
hope this helps :y
Post by: Darth Loo-knee on 16 April 2009, 15:37:16
What do you mean? if thet are 3.0? or which is the inlet ot exhaust? there are "A" and "G" stamped on the edge if that helps :y
Post by: Martin_1962 on 16 April 2009, 16:20:58
If they are not - you sold them to me!
Basically inlet and exhaust
Post by: Darth Loo-knee on 16 April 2009, 16:22:12
 ;D
They are 3.0 ones if they are the ones you had off me :y
Post by: Matchless on 17 April 2009, 13:23:48
Martin,
The cams have a pair of thrust faces either side of the front bearing, look at the periphery of the rear thrust face and you should see engraved a letter and batch number. The letter lines up with the table posted above.
So you want two 'A' cams for the exhausts
and two 'G' cams for the inlets.
Post by: Elite Pete on 17 April 2009, 18:05:28
 ;D
Didn't we get the knobbly sticks out of the old A series engines we had lying around ::)
Post by: Marks DTM Calib on 17 April 2009, 18:12:54
 ;D
The only engines I saw were 2.5's!
Post by: MutantCav on 17 April 2009, 18:45:28
The letter/number is engraved on the edge near the end i.e. G7  :y
