Omega Help Area => Omega General Help => Topic started by: Jimbob on 17 April 2009, 19:03:58
Title: EGR and carbon dust
Post by: Jimbob on 17 April 2009, 19:03:58
My EGR used to leak, so long been blanked off with coke can
Had the bonnet open, and noticed lots of carbon dust on drivers side cam cover area, looks to have come from EGR
Any ideas anyone?
Title: Re: EGR and carbon dust
Post by: Marks DTM Calib on 17 April 2009, 19:30:48
Is the corrugated pipe to the EGR split?
Post by: Jimbob on 17 April 2009, 19:40:25
Looks ok.
There is dust on the torx bolts that  hold the egr on,
on the cam covers and leads
on the fuel pipes
and the metal coolant pipe below.
So quite a bit of coverage
Looks to be from the egr itself.
Post by: dbug on 18 April 2009, 00:43:26
Looks ok.
on the fuel pipes
Mine looks a bit like that too
Post by: Jimbob on 18 April 2009, 10:49:34
Looks ok.
on the fuel pipes
is yours blanked as well?
Post by: Jimbob on 23 April 2009, 19:39:14
Took the EGR valve off, and there in my old coke cans are 2 great holes, looks like its burnt through.
Replaced and will monitor.
Old can was aluminium, and replaced with the same, couldnt find a steel one to try instead.
Post by: tmx on 23 April 2009, 19:42:14
yeah my coke can burnt though so i made a plate up out of proper thick steel that didnt burn through but i got hold of a cheap egr so just replaced mine in the end
Post by: Jimbob on 23 April 2009, 19:49:50
Vauxhall do sell the proper blanking plate for this now, Paul W found it, cant remember the price though  :-/
Post by: tmx on 23 April 2009, 20:00:54
must be all of 99p odd? does blanking it off upsetr it much? i only blanked mine as a temp fix
Post by: Pete Elite on 23 April 2009, 20:12:07
  Apparently not at all :).
Post by: dbug on 24 April 2009, 00:30:46
Looks ok.
on the fuel pipes
Don't think so JImbob, but can't be certain.
Post by: Jimbob on 24 April 2009, 07:06:05
Looks ok.
on the fuel pipes
Ahh then blank it off  ;D
2 torx bolts, cut the shape of the gasket out a can, then put the can on, gasket on, and egr on the top.
