Omega Help Area => Omega General Help => Topic started by: Omegatoy on 25 April 2009, 20:27:59
Title: Re: Running out of day light!
Post by: Omegatoy on 25 April 2009, 20:27:59
neither of these should stop it starting!!! would bet it just wants bleeding the injectors unless of course you forget to put a connector in somewhere?? if you have brake cleaner handy remove the large black pipe from the airfilter box end and get someone to turn the engine over on the key while you squirt brake ceaner in the intake pipe it will fire up on the brake cleaner and should then keep running on the diesel it sucks up! :y
Post by: Seth on 25 April 2009, 21:33:11
Slacken-off the injector pipes at each injector, then crank the engine until you see fuel squirting from each pipe. Tighten the pipes, turn on the key until glow-plug light goes out, then try to start.
Post by: ali on 25 April 2009, 22:03:53
ok thanks will try tomorrow when Ive recharged the battery :)
