Omega Help Area => Omega General Help => Topic started by: ali on 29 April 2009, 09:50:37
Trying to get Pete through MOT one of the things are indicators wrong colour, ( side and front ) is this just the bulbs? also front light will not adjust so do I need a whole new light? By the way Syd is running fine ;)
yep just change the indicator bulbs the yellow will have flaked off.
Headlights the adjusters rarely work and break far to easily, but you should be able to get to the wheel on the back and turn that rather than the allen key on the top. Much more fidely though. Failing that some bodgeing/moving the brackets may get them in line. GM headlights are very expensive i beleive, copys can be had for 80 each although the build is poor(adjusters even more frail) the beam on the road is comparatively good. Or breakers on here for used.
hth
ok thanks, if I can adjust it how do I know where to point it :D :D :D
