Omega Help Area => Omega General Help => Topic started by: raywilb on 06 May 2009, 12:40:16
Title: diesel magic trick
Post by: raywilb on 06 May 2009, 12:40:16
had great interest in cockyt1,s thread,as certain things pertain to me. my question is - can i just drain the fuel filter via drain plug ,remove top banjo bolt and fill with d m . the fuel filter has only been on two weeks. my tractor has no probs in hot or cold starting, but 64 is showing. peizo lead may be at fault as suggested on cockyt1 thread,as apart from eml light and a moments lack of power (only occasionly) the tractor runs ok.  Ps, its been like this for a long time. :-/ :)
Title: Re: diesel magic trick
Post by: platty on 06 May 2009, 12:49:36
As far as I am aware, the drain at the bottom of the filter is only to let water out which may have accumulated (correct?).
The best bet is to whip the filter off and empty it out, you can then just fill it with diesel magic (in the centre hole) and refit. When you start it up, hold the revs at about 1500 for a minute or two and then take it out for a blast for 10 mins.
I have done this every 6k since I had the car (about 6 times), and it runs better now than it ever has done - don't expect ti to be perfect after the first go, it might take a couple of flushed over time.
Post by: platty on 06 May 2009, 12:49:50
I have done this every 6k since I had the car (about 6 times), and it runs better now than it ever has done - don't expect it to be perfect after the first go, it might take a couple of flushed over time.
Post by: ali on 06 May 2009, 13:03:16
I have been doing the diesel magic thing, its much easier to take the filter and housing off. Its so easy Ive had it off 4 times this week! In cockyt1 thread they talked me through how to do it, or was that 2.5 td trouble starting :D :D :D Ive had a lots of questions  ; ;D ;D and lots of help ;D
Post by: raywilb on 06 May 2009, 14:47:53
cheers  :y :y :y .tomorrows job if weathers ok  :y
Post by: Omegatoy on 06 May 2009, 20:59:31
LOL reading this thread has made me wonder just how many people the diesel magic trick has helped? i first discovered it by accident but it has cured so many tractors and rangerovers and BMWS now ive couldnt even begin to guess!!!!! and it all came about cos vauxhall wanted a fortune to change the injector pump!!!! of course me being me had to find a way of sorting it meself, wonder how much money they have made out of poor running tractors !!! :y
Post by: Seth on 06 May 2009, 21:16:47
Do you reckon that Diesel Magic is better than Forte?
Forte's not always easy to source, and is around 13 to 15 quid a bottle, though I've had good results.
Any idea where I can source it, and how much? Thanks mate!
Post by: Omegatoy on 06 May 2009, 21:29:21
to be honest they are both about the strongest on the market thanks to H .and Safety piilocks saying the brit public are idiots and cant handle strong chemicals, diesel magic is sold in halfords stores mate, forte is usually available on ebay if you look but both do an equally good job!!
Post by: raywilb on 06 May 2009, 21:29:27
omegatoy , it was a guy like you that probably invented the wheel. seriously i was in awe at the guys stuck in mddle of a footie pitch (york) doing tasks with ease that a vx dealer would charge the earth. it amazed me how clean they kept themselves too. yes it was good to watch.  :y :y :y :y
Post by: ali on 06 May 2009, 22:12:41
do a poll ;D
I actually enjoy doing the diesel magic thing and have it down to under 10mins now.On my 3rd go now ;)  Not like the first time running in and out of the house, with clingfilm on the lap top asking daft questions :D :D :D :D Im very pleased you found it and so is my bank balance :y
Post by: Ian_D on 07 May 2009, 00:15:45
Should I treat my tractor to some DM then?
Or should I leave it since it now starts on the button and runs ok? Ie - If it aint bust, dont fix it!  ;D
Post by: Pitchfork on 07 May 2009, 10:08:27
Have done it once a couple of weeks ago to try to cure misfire (only when cold) but has had no effect, believe I have a dribbling injector
Post by: ali on 07 May 2009, 10:10:49
Your brave to admit that on here ;D ;D ;D ;D ;D ;D ;D ;D ;D guess its an age thing ;)
Post by: Omegatoy on 07 May 2009, 20:21:59
lolololol :y
Post by: Omegatoy on 07 May 2009, 20:23:11
possible but diesel magic should have improved it if it was? would have thought that stuck egr or poor quality fuel was more likely ifits only when cold?? :y
Post by: Pitchfork on 07 May 2009, 20:37:57
Usually Sainsburys but on occasions gets BP or Tescos - no difference
Post by: Pitchfork on 07 May 2009, 20:41:15
Certainly is & we get soup later!! ;D
Post by: Omegatoy on 07 May 2009, 20:56:15
Am assuming its not a glowplug gone down
ok try this then, remove the back cover today, then in the morning when its cold start it and as its missfiring put a finger on each injector pipe in turn, you will feel them pulsing as the engine runs the weak one will not have as strong a pulse through the metal pipe,  its amazing just how much of a difference there will be, if one is definetly weaker then obviously change that one!! assuming again there isnt a leak at the other end where the pipes screw into the injection pump!! there is a seal there that can weep! :y
Post by: Seth on 07 May 2009, 21:41:53
Cheers Omegatoy,
Markseth's latest tractor is coming in next week for the full monty plus MoT.
So if Diesel Magic's good enough for you, we'll use his tractor as the guineau pig!
If I'm happy with the result, then mine'll be getting a drink at every 2.5K oil-change too.
There's been some debate in the recent past regarding diesel fuel quality - mine runs miles better on 'proper' juice, and definately less emissions. I avoid the 'supermarket-type' cut-price stuff, and I'm certainly not the only tractor-owner to confirm this.
Post by: Omegatoy on 07 May 2009, 22:20:01
Cheers Omegatoy,
easiest way to tell about supermarket fuel is run the car for 2 tankfuls and check how many miles it does, then run it 2 tankfuls on good stuff and see the difference this assumes same route travelling to work etc etc but the difference is there!! in the waynthe car performs as well as economy!!! hope the service goes well bud!!!! :y
