Omega Help Area => Omega General Help => Topic started by: megaomega123 on 12 May 2009, 16:39:18
My osf camber is sitting at -2.75 How do I adjust it back to the -1.1 where it should be?
Can you get the offset bolts from vauxhall? :-?
you have to undo the nuts on the hub to shock and ajust that way with a spirit level
but you will never get it 100% mate
Yep, then a trip to you local alignment people is a must for accuracy!
How do you adjust after undoing bolts? The bolts go through at right angles to the camber line.
I have access to laser alignment equipment and camber/castor reader.
when bolts are loose the wheel will move from the top either in or out
Thanks for that. I shall have a bash tomorrow or next week. :y
do it asap or it will chew your tyres :y
