Omega Help Area => Omega General Help => Topic started by: penny628 on 10 May 2009, 22:35:10
Title: Help water pump and power steering gone
Post by: penny628 on 10 May 2009, 22:35:10
Please can you help me, the power steering and the water pump have gone on my omega 2.5 cd v6 is it an auxillary belt that controls these or is it the timing belt my car is T reg
Title: Re: Help water pump and power steering gone
Post by: Andy B on 10 May 2009, 22:37:43
It's your auxillary belt that's gone. Don't drive it lke this though, you'll cook it, aswell as having biceps like Arnie!  ;) ;)
Post by: penny628 on 10 May 2009, 22:49:28
thanks the vauxhall garage have ordered me the timing belt thought it was an auxillary belt is this a hard job to fix
Post by: Bent valve on 10 May 2009, 22:57:38
It is one of the easiest jobs to do on an omega. get yourself a Haynes manual it explains most things.
Post by: dbug on 11 May 2009, 01:50:23
Check out the tensioner before fitting new belt!
Post by: TheBoy on 11 May 2009, 08:40:18
Easy enough to change, though you may need to strip out part of the intake (can be done without, but fiddly).
As said above, check tensioner condition
Post by: spursyid on 12 May 2009, 20:45:24
Same happened to me 2 weeks ago,As long as you didnt drive for long you should be fine,Mine as i was told on this site was the aux belt the spring loaded tensioner had gone(bearing siezed)just check all pullys they should all turn apart from the crank,Easy job as long as you have a diagram to help you with the long aux belt. :-*
Post by: dbug on 12 May 2009, 21:07:13
Aux belt fitting diagram - hope it helps :y
(http://www.dbug.co.uk/pics/V6AuxBelt.jpg)
Yours is probably the middle one if you've got air con ;)
Post by: tmx on 12 May 2009, 22:48:25
when you refit it make sure with engine running that none of the pulleys are shaking especially the crank pulley
Post by: penny628 on 12 May 2009, 23:39:27
Thanks very much for the diagram and all your help have got the pump in now just have to fit it up to the pullys will check the tensioners the haynes manual was doing my head in
