Omega Help Area => Omega General Help => Topic started by: 3.0V6Elite on 16 April 2009, 20:34:28
I think that my exhaust is blowing at the join between the front pipe and the manifold, might possibly be on both of them as it's a 3.0 V6.
I have recently had the cylinder heads off due to the gaskets going, and since putting it all back together the exhaust seems to be blowing a little until the system gets hot.
I torqued the nuts up properly to the studs on the manifolds, so am reluctant to tighten them any more to avoid snapping them, but is there anything else I can do. Maybe some exhaust sealing compound?
Any advice welcome. :)
Did you put the multi layer exhaust manifold gaskets on?
Did you use new manifold gaskets, guess you have?
Or this maybe where the manifold joins cat's, did you replace gaskets there to?
New multi layer manifold gaskets were used when it was put back together.
By this I guess your refering to the downpipes. I didn't realise that there were gaskets there as there didn't seem to be any when removed. :question
There is a ring type gasket on both side's i would say that's where your blow is coming from as you will hear it clearly ish... :-/
I know the one's you mean. Guess I will have to replace them and see how it sounds! :y
Could be worse, not an all that bad job to do. :y
Finally got round to replacing the ring gasket between the manifold and the downpipe today. Luckily it was just the o/s one that needed replacing as I couldn't get the lamda sensor out of the n/s downpipe. She is purring like a kitten now! :y
Thanks for the advice given! :)
Your welcome mate, glad it was only that one as manifold would have been a pain to do :(
Hope to see you at a meet soon :y
Yeah me too!
