Omega Help Area => Omega General Help => Topic started by: Proz on 18 May 2009, 16:23:44
Hi all .... just a quicky
When i unscrew the power steering cap the stick thing on the bottom of it has 2 lines about a centimeter apart .... is that the level indicator , ie the same as the oil dipstick .
Cheers
Yep :y
Yep :y
Cheers :y ... i thought it was but wasn't sure ..... mine needs topping up then :y
Woah! Your fluid may not need topping up. The two marks on the dipstick are:
Lower one - Correct level for a COLD engine.
Upper one - Engine at normal operating temp, you should never overfill the reservoir.
Mmm yes never thought about that .... havn't done it yet but ill take her for a spin before checking again .... Thanks :y
