Omega Help Area => Omega General Help => Topic started by: richy08 on 24 May 2009, 21:14:53
Title: injector problem
Post by: richy08 on 24 May 2009, 21:14:53
hi guys got a hot start problem for a bit now still cant cure it and a problem with running at about 70 mph it seems to lack power and hold back when going up a hill then she will drop a gear but i found that if i crack the injectors 1 -6 it cuts out at no. 4 if i get someone to keep the revs on and crack it then it solves the holding back and droping gears problem .do ye think that i need a new injector .. :y oh done PC.test nothing  :y thanks guys if anybody selling a second hand turbo il have it .
Title: Re: injector problem
Post by: Turk on 24 May 2009, 22:55:26
This may be worth checking out.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=220387365430
Have you done a "paper clip" test ?
Post by: richy08 on 25 May 2009, 10:14:18
ya i done the paperclip test , nothing i was looking at that hot start thing do u no if if works i rang the bloke from there he said it is made for land rovers but will work
Post by: Turk on 25 May 2009, 11:46:33
The 2.5td has been used in several vehicles.
Not used it myself, but if you supplied the details of your engine and he says it will work, you have that in print if it's not compatible.
Post by: richy08 on 25 May 2009, 12:39:17
thanks for that wot do u think about the injector no. 4 should it cut out when i crack it  :y
Post by: Seth on 25 May 2009, 15:08:32
Hmmm, not sure - but - it incorporates the 'start of injection' sensor.
It may well stall the engine, as the sensor recognises a sudden drop in pressure when the pipe is slackened.
Post by: Seth on 25 May 2009, 15:12:03
I reckon this device works okay.
If this problem re-occurs on mine, I'm gonna fit one!
Post by: richy08 on 25 May 2009, 17:41:50
well as ye know there is a sensor on injector no.  4 but it seems to solve my holding back power problem i am thinking that the problem but u guys told me a bit ago it could be the injector pump i have a spare pump i just dont want to pay to have it fitted if i dont have to credit crunch lol thanks guys any ideas welcome  :y :y
Post by: Seth on 26 May 2009, 18:15:11
You say 'holding back' .......
Does your car feel like it's permanently towing another car?
This happened to mine, shortly after fitting a new injection pump. My EML was permanently on, and correctly threw-up codes 81/82.
No4 injector changed, EML went out, and right as rain since (touch wood!).
Is the EML lighting-up when the ignition key is in position 2 - proving that it actually works?
(Just wondering if some 'herbert' hadn't previously removed it to 'hide' this fault).
Post by: richy08 on 26 May 2009, 19:17:12
i have a second hand pump but dont want to fit it unless i have to. thats the best way to explain it towing a car like the brakes locked on i put a ar35 box just wondering if i put the chip in would that cure it ?  :-? :-?
Post by: Seth on 26 May 2009, 19:58:14
It sounds awfully like that No.4 injector's at fault here, though I can't understand why the EML isn't lit up, or that no codes have showed on the paper clip test.
Are you sure that the EML is working when you turn the key to position 2?
Very carefully check the wiring from this injector back down to the multi-plug below the inlet manifold.
