Omega Help Area => Omega General Help => Topic started by: omegav6est on 28 May 2009, 00:52:50
Title: air con "coldness"
Post by: omegav6est on 28 May 2009, 00:52:50
hi all the air con on my mig works as it should except i am doubting the coldness on its lowest setting.it does get cold but not icy cold as i am told it should be.according to the service history the car had a new air con compressor and a regas at vauxhall last year but this was before i had it so i dont know how cold it was then.i know i can get it checked out at  a specialist but i was just wandering do these systems get very cold or is mine normal.thanks
Title: Re: air con "coldness"
Post by: dbug on 28 May 2009, 01:05:43
Mines icy cold - not been regassed in the 2+ years I've had it!
Post by: p j morgan on 28 May 2009, 01:20:15
they should be icy cold ,you probly need your gas topping up .you no what vx are like ,can't be trusted to do a proper job!  :y
Post by: Omegadoha, Desert Member on 28 May 2009, 04:27:56
Check the valves first. They could be leaking very slowly.
