		Omega Help Area => Omega General Help => Topic started by: semisheen on 28 May 2009, 15:22:44
				Yep its somting else today the 2 fans in front of the condensor are running all the time ...ive walked away gone back 2 hours latter and they are still running (not at max speed) but running all the same im pretty sure they would run all night too if i hadnt disconected the battery ....
Any ideas Folks ?
				Look around the forum, cause I think I've seen question like this before
				mee too but cant seem to see it
				My brother had this on his elite and found one of the large blade fuses in the fuse box under the bonnet had blown, something to do with a get you home mode, so check the fuses mate, also it drained the battery real quick.
				Check rad switch - unplug it is easiest test.
				Thanks everyone ...it was the rad switch .... :y
