Omega Help Area => Omega General Help => Topic started by: Andy2009 on 28 May 2009, 09:51:08
Hi
The rear door on my 2002 Omega is locked and I cannot open it using the central locking or the lock button on the door. I undertsnad that I probably need to replace the motor but I need to get the door open before I can access the motor etc
Any ideas on how to open the door would be very gratefully received.
Thanks Andy :(
Is there no button you can prize up?
Can you get the door card off ?
Hi
Ive tried prizing up the button and the door card access appears to need the door open
think I would try prizing the button up again mate.
As for the door card removal, you may need to remove the rear seat (only the bit you sit on)
i had the same problem, it turned out 1door had deadlocked its self had to end up paying Vauxhall £75 to get it opened :-/
