Omega Help Area => Omega General Help => Topic started by: tommycon on 19 May 2009, 17:54:29
Title: heater blows cold air in back of car
Post by: tommycon on 19 May 2009, 17:54:29
hiya,
 think i may be doing something wrong here, i turn heater blower on and get warm air at the front but very cold air blows out of the rear facing vent between the front seats,
any pointers?
 cheers.
 paul
Title: Re: heater blows cold air in back of car
Post by: tmx on 19 May 2009, 18:44:15
have you got Electronic Climate Control? heater that you set the temp to like 21"c? if so its supposed to do this as its regulating the temperature by blowing hot from some vents and cool from others so it gets a temperature of what ever you set it too
Post by: tommycon on 20 May 2009, 17:22:18
yeh i`ve got the electric type with 2 independent settings, even when i put them both on high it still blows cold at the back.
Post by: tmx on 20 May 2009, 17:25:29
ahh is it now!
Try this.... Hold the AUTO & OFF buttons together turn the ignition to II whilst still holding the two buttons the climate control will start to hopefully make some noises whilst it recalibrates the servos once it starts making this noise left go of the 2 buttons that may fix the problem :y
Post by: tommycon on 20 May 2009, 17:31:05
nice one thanks,
 i`ll try it after my tea.
 cheers
Post by: gazsomega on 06 June 2009, 21:34:08
i have that problem i will go try in a min
Post by: James Q on 06 June 2009, 21:44:31
is this a common problem?
Post by: swamp rat on 07 June 2009, 11:59:15
Happens a lot with the front blowers. I think driver's side servo controls the back also. There is a servo and air distribution thingy in the driver's footwell, left hand side. If you remove the cover above the pedals, you can see the servo up in the footwell above where the carpet ends. It's not too bad to remove if you have small hands. Behind the servo motor is the air distributor. It has a plastic clip on the front to control driver's compartment and a metal rod hooked in at the back to control the rear. These have been known to fall off. I'm sure I found a how 2 on here when I had the same problem with the driver's compartment.
