Omega Help Area => Omega General Help => Topic started by: howardmoon on 07 June 2009, 10:13:08
Title: Key fob battery replacement
Post by: howardmoon on 07 June 2009, 10:13:08
Hi, my keys are 11 years old and as far as I know still have the original batteries. lately I've noticed it doesn't always work first time, and I have to tap the key on something first. How do I replace the batteries, do I have to get Vauxhall to do it?
Cheers, Paul
Title: Re: Key fob battery replacement
Post by: Jimbob on 07 June 2009, 20:42:29
small indent in the back of the key,
either use this, or pull to separate fob from 'horseshoe key'  (take care not to lose immobiliser transponder, small black plastic bit)
then gently separate both sides of the fob, carefully remove and replace cr2032 battery, and reassemble.
You have about a minute to do this before the fob 'loses' programming
if it does, just key in ignition to position 1, then press either button, locks activate, and fob resync'ed.
enjoy!
Post by: KillerWatt on 07 June 2009, 21:19:53
Check the battery post legs (the one in the corner), they have a habit of "fracturing" away from the PCB.
A slight pain to resolder, but can be done.
Post by: howardmoon on 08 June 2009, 16:42:55
Cheers guys, I'll do a google search for the battery type as replace the one in the spare key too. :y
Post by: markey mark on 08 June 2009, 16:58:46
its a 2032 battery bud  :y
Post by: dbug on 08 June 2009, 18:41:52
You should get one from any good Computer Shop - they are used on mobos to power CMOS!!
Post by: Jimbob on 08 June 2009, 18:50:58
Sod that, any battery shop, supermarket, wilko's etc, one of the most popular out there!
Post by: dbug on 08 June 2009, 18:54:43
Sod wot?? I used to sell em in my shop for £0.50 each!!  Rover dealers used to sell em (2 required in 827 key) for £6.50 each!!
Post by: Jimbob on 08 June 2009, 19:13:18
No offence....these days good computer shop = online = delivery
pick em up in any number of shops in most towns now, from £1-3  :y
Post by: Martin_1962 on 08 June 2009, 22:04:03
I bought a pack of 50 for about £15
Post by: howardmoon on 09 June 2009, 12:06:03
Cheers guys, it turns out my computer on my pushbike uses the same battery and i've got a spare already. Changed and working just fine
Thanks, Paul :)
Post by: dbug on 09 June 2009, 17:10:10
None taken ;)
