Omega Help Area => Omega General Help => Topic started by: semisheen on 11 June 2009, 22:38:43
Title: Automatic lockup in 3rd & 4th
Post by: semisheen on 11 June 2009, 22:38:43
Can somone please explain this ....as i seem to be missing the point  :-/
Title: Re: Automatic lockup in 3rd & 4th
Post by: Lizzie_Zoom on 11 June 2009, 22:42:44
It is used to keep the auto gear box in a low gear, 1st, 2nd or 3rd, when slowly climbing a hill (say behind a lorry) or decending a very steep hill when you need to keep in a low gear.  As you would in a manual. ;)
Is this what you meant? :-?
Post by: Kevin Wood on 11 June 2009, 22:50:37
Lockup bypasses the torque converter, which is the device that takes up the drive as engine RPM increases and provides a variable gear ratio at low speeds.
At cruising speeds  the torque converter is inefficient so a clutch is engaged to bypass it.
http://en.wikipedia.org/wiki/Torque_converter
Post by: semisheen on 11 June 2009, 23:13:04
Thanks for your replies once again
I thought “automatic lock up” basically locked 3rd &4th …cruising speeds as previously mentioned
Where am at  right now is I bought some Dextron 3 the other week I then couldn’t get the nut undone ive had it on the 4 poster today and still couldn’t undo it (didn’t want to risk it with a chisel)so it looks like its sump off this weekend & get some heat on it
I also plan to change it to manual soon but not soon enough has  on average it does 20 to the gallon this morning going to work it changed in to 4 at 100mph and it was shifting from 4th back to 3rd …….so heres were me diesels going me thinks at idle it uses 0.3 gph which I would think is about right
I’ve always had manuals in the past 1st / 2nd/ 3rd is  fine it will go in to 4th driving extremely gentle (no gradients) at around  40 mph touch the accelerator & it goes straight to 3rd (hardly kick down ) …I know im answering my own question here but I need to change the gearbox ATF 1st and go from there before anyone can answer my question
Post by: p j morgan on 11 June 2009, 23:31:42
think you have got to check transmissiön fluid?then  possibly the eilter hope this helps ?
Post by: semisheen on 11 June 2009, 23:47:57
the eilter ????
Post by: hotel21 on 11 June 2009, 23:58:43
got me with that one....   :-/
Post by: zirk on 12 June 2009, 01:20:49
Lock up on a 2.5TD auto should occur around 50 to 60 mph in top gear if your light footed, maybe check your engines pushing the right power as it sould. If it kick's down too soon under load I would suspect engine power.
Post by: p j morgan on 12 June 2009, 01:42:25
sorry about ilter bit ave you   tried writing a message or anything with a mobile  fone? My bloody laptop packed up  last week sorry guys!
Post by: Andy B on 12 June 2009, 01:45:01
C'mon then....... buy yourself a new lappy! how d you exect us to understand  you othewise?  ;D  ;D  ;D  ;D  ;D
PS I thought phones were for making phone calls   :-/   ;D  ;D  ;D
Post by: p j morgan on 12 June 2009, 01:56:28
looking for one at the moment .ave to use my fone to go online not bad realy only a fiver a month  and you can go online anywhere getting use to it now well nearly.
Post by: semisheen on 12 June 2009, 10:55:13
I do computers for a living ...but ive not got any laptops at the moment PM me if your strugling ....im not far away
