Omega Help Area => Omega General Help => Topic started by: star_whites on 12 June 2009, 22:04:16
Title: V6 Knock sensor
Post by: star_whites on 12 June 2009, 22:04:16
Ok I have my replacment front knock sensor for my 3.0 V6.
Now tell me where is this fitted to the engine. I know the cable connects to the multiplug that mounts to the cable tray on the cam belt cover but where does the other end fasten to the engine????
Hoping to get this fitted first thing in morning so any help appreciated  :y
Title: Re: V6 Knock sensor
Post by: razzo on 12 June 2009, 22:14:28
if its driver side it sits between alternator & the block remove top bolt on alternator, loosen bottom bolt, swing alternator to the left & all will be revealed
Post by: star_whites on 12 June 2009, 22:18:28
Excellent, thanks razzo
Will hopefully get this changed first thing along with my new dipstick tube and that should fingers crossed be that for a while  :y
Post by: razzo on 12 June 2009, 22:23:30
if yours has been munched by the aux belt a re route on assembly may be a good idea
Post by: Bumbazor on 12 June 2009, 22:25:30
You still ok for us to pop along tomorrow?
If you don't get it done by then I can still help if you like
Post by: star_whites on 12 June 2009, 22:29:18
Yeah thats fine Tom, nothings changed except for an additional temporary lodger.
I will have to reroute as it dragged in aux tensioner and is in two pieces  :-/ ::)
