Omega Help Area => Omega General Help => Topic started by: over50now on 16 June 2009, 09:06:29
1999 V6 Tourer.
Crank sensor. Is it the plug, just to the left of the crank pulley, as you look at it (i.e. drivers side of crank pully). Asking 'cos advice received concenrning fault codes indicate crank sensor knackered. Have noticed that it is covered in old oil, grease and dirt. Would a good clean recitify before I buy a new one. Thanks
crank sensor is located next to oil filter passanger side :y
Thanks Serek. Would have been cleaning wrong sensor and then when it didn't work replacing wrong sensor. :-[ Thanks again :y
Try this link it may help.
www.omegaowners.com/forum/YaBB.pl?num=1174321688
Thanks Ghost Driver.
As per normal Marks DTM is top dollar :y
