Omega Help Area => Omega General Help => Topic started by: Martin_1962 on 16 June 2009, 18:49:35
Title: Sometimes difficult to start
Post by: Martin_1962 on 16 June 2009, 18:49:35
Compression OK, cam timing OK, may be a small air leak on the inlet - will fix when the 135 head gasket is replaced.
Have to use some throttle to start and it wizzes on the starter motor.
Would this be the start of crank sensor failure?
Title: Re: Sometimes difficult to start
Post by: Martin_1962 on 16 June 2009, 18:49:59
BTW this is sometimes - usually starts easily
Post by: The Cambelt Kid on 17 June 2009, 00:10:14
Sounds like the crank sensor to me.  I didn't think of this when mine started to fail, but i soon realised!
About £40 notes AFAIR
Post by: hotel21 on 17 June 2009, 00:23:14
codes?  Really need to explore that first, wouldn't you agree??
Post by: Martin_1962 on 17 June 2009, 07:52:33
No new codes
Post by: feeutfo on 17 June 2009, 08:32:03
mine had a few episodes(4?) like this last year on really hot days parked up in the sun. Long crank on the key and a bit of a spltutter. No codes, not happened again since. Strange. Yours sounds a bit more regular though...?
Post by: cem_devecioglu on 17 June 2009, 08:41:34
Sometimes happen to me also in hot days although the cranksensor is brand new (vx-so is cam sensor)..
I think either the fuel comes late or is too much :-/
and deffo no eml light..
Post by: feeutfo on 17 June 2009, 12:20:51
thankyou cem, you reminded me, God my memory is crap. I have a tendency to put the key in and turn straight away, starting the engine before all the dash lights have gone out. Nothing unusual possibly, but a friend has a Lexus is 300 that is quite bad in this reguard. The fix is simply to allow the dash lights to go out, which gives the fuel pump enough time to prime the injectors and away it goes no problem. Apparently its been fine since following this rule.
Testing this theory on the omega when it only happens a few times a year will be difficult i guess and may not be part of the problem anyway. Who knows...?
But in Martins case if its unusual for his car and considering all the work done recently, i might be checking inlet and fuel etc.
Post by: Martin_1962 on 17 June 2009, 18:33:32
Fuel - hmm
Well I should be having a visitor this weekend who can help me
Post by: cem_devecioglu on 17 June 2009, 20:54:56
 :) :y
