Omega Help Area => Omega General Help => Topic started by: V6Astra F on 15 June 2009, 18:38:41
Title: Will This Ecu Work ?
Post by: V6Astra F on 15 June 2009, 18:38:41
Hi
Ok i got my SAI sorted with the motronic 2.8.1  :y . Now i got this extra ecu but i dont know if it will work with the valves on the intake . Numbers on it are 90 457 098 & 0 261 203 272/273   FS . I had it in the car when i used the C25XE intake , using a Vectra B X25XE intale now . Just want to test it because i cant get those valves to work  :-? , but i need to know if this ecu supports them .
Thank You
Title: Re: Will This Ecu Work ?
Post by: V6Astra F on 19 June 2009, 08:00:09
Ok i found out that its a Motronic 2.8 from a X30XE , thats all i came up with
Post by: TheBoy on 19 June 2009, 09:00:22
AFAIK, that was only fitted to Omega and Sintra. Seeing as Sintra is pretty rare, its most likely Omega, and thus would have the Omega Multiram config.
Unsure if using a map chip from a Vectra would help, as presumably the valves are part of the map  :-/ - but that is purely a guess.
Post by: V6Astra F on 19 June 2009, 09:23:45
Thanks , im going to give it a try this weekend then  :y
