Omega Help Area => Omega General Help => Topic started by: miniator on 22 June 2009, 15:21:29
Title: Strange oil warning...
Post by: miniator on 22 June 2009, 15:21:29
driving around town no faster than 40mph; no sign of the warning on the CID.
but out on the open road, 50mph+ and particularly at 70mph i get the "CHECK OIL LEVEL" warning fairly often. maybe 6 times in 40miles travelled.
oil level is fine and always has been fine since i got the car, definitely isnt burning any. no oil light on the dash either
i assume its a sensor giving duff readings.....any other ideas?
Title: Re: Strange oil warning...
Post by: gav525 on 22 June 2009, 15:37:25
I get this an all, and the oil is only after being changed so is at max!
Be good to know whats causing it?
Post by: miniator on 22 June 2009, 15:41:09
i always get passengers looking at me with a rather concerned look when i just hit ok and ignore it lol!
Post by: gav525 on 22 June 2009, 15:45:37
Lol, same here. Thought it was something to do with the rocker gasket at first, but thinking it is the sensor now.
Post by: TheBoy on 22 June 2009, 15:58:26
If the oil is halfway between min and max, this is normal, particularly on hotter days.  Keeping it up nearer max stops this.
Other than that, sensor (particularly if poorly serviced in the past) or wiring issue.
Post by: miniator on 22 June 2009, 16:02:17
umm my oil level would be bang on between the two markers so ill top it up nearer the max and see. and your right, it is mostly on hotter days it happens
why would it do that? is it something to do with the oil cooler?
Post by: deviator on 25 June 2009, 14:06:28
It's more likely to be the oil level sensor.
However, it's a sump off job to get to it. Try the oil level top up first.
Post by: miniator on 25 June 2009, 14:07:47
stuck half a litre of oil in, and sure enough, no warning! amazing lol
Post by: Richard A on 25 June 2009, 17:41:37
Please, please, check oil level after 5 minutes after engine has stopped, on flat ground, then top-up to max level. Problem is the oil sump is flat in design, so at speed, even worse up hill, the oil flows to the rear ie away from the sensor.
So always keep oil at maximum level.
regards
richard a
Post by: Ian_D on 25 June 2009, 23:54:24
I got this message when I was towing my caravan back home (from Northampton to York) and I had 'Selective' reading I think, and just read the 'Oil' part and thought the worst! :o :o
Bearing in mind this was the second time I've ever towed, I was on my own, and was about 100miles away from home! On top of that, I was worried that the car was running a bit hot too!  :-X :-X
Slowed down a little bit, and then I remembered that the worrying message is 'Oil Lack' not ‘Check Oil Level’, so panic over!  ;D
Checked the oil when I got home, and it was about 2/3 up between the Min – Max. :y
