Omega Help Area => Omega General Help => Topic started by: spikerz on 24 June 2009, 14:32:03
going from neutral to drive or reverse the revs drop and it sometimes stalls?
what does your r p m read on tickover? does it happen all the time?
sorry i meant to say does it do it when the engine is at the right temperature?
just been trying it now, not started from morning. tickover is about 700.when i go into drive(or reverse)it drops to about 500(but not as low all the time) and quickly revs back up again.i think occasionally it drops below 500 and this is when it stalls.it usually does this from cold but i think it's stalled more after its warmed up.just going out for a short run just now so i'll see what its like when its warmed up and i'm back.(just had it for a few days now)
forgot to say..it stalled once going round a corner(fairly slow)
Crank sensor :y
stalled once when out(neutral to drive)
Tick over revs and the way the revs drop etc.seems to be the same when warmed up too.
Anyway another thing happened...when pulling away from the last set of lights,it was revving but hardly moving so i had to use the manual gears.The auto box fault warning came up on the display so i pulled in when i could and switched it off.switched it on again,fault warning gone and it drove normal again.autobox working as it should?
Do you know when the auto box was last topped up serviced? :-/
the guy i bought it off said a seal had been replaced in the gearbox and oil changed.
Worth checking the level ?
i'll take it to my brothers workshop tomorrow and check oil level.
so do you think the crank sensor needs replaced anyway?
That was the problem with mine. I got code 19 when I did the paperclip test, not sure if you can do the test on a diesel though - I'm sure someone here will know or look in the 'how to' guides. :y
Works on some 2.5's...............
i have checked the gear oil level and it is correct.the automatic gearbox fault always comes on now,i can only use gears manually.is there anything else i can check?
