Omega Help Area => Omega General Help => Topic started by: Dubious on 25 June 2009, 20:38:09
Title: Removing wiper arms on facelift
Post by: Dubious on 25 June 2009, 20:38:09
Am I an idiot ? There's no thread for this that I can find.
Trying to remove the wiper arms (to get the scuttle off). Removed cap, nut and washer but can't get the arms to budge. WD40 and moderate levering / bashing but no joy. Should they just pull off, or is there more to it ?
Thanks.
Title: Re: Removing wiper arms on facelift
Post by: KillerWatt on 25 June 2009, 20:42:14
Push down on the arm to relieve the tension (that applies to all cars).
Post by: Dubious on 25 June 2009, 20:47:09
Thanks - I'll try that.
Post by: Entwood on 25 June 2009, 20:50:17
I raise the arm to vertical, then ensure that the the bottom part is square .. then just lift off.
The problem is that while the arm is down, pressing on the windscreen , it rotates the part that goes on the stub and it doesn't sit square .. so is hard to take off.
Pressing down on the arm, as advised by the previous poster does the same thing .. it squares up the bit on the stub.
When replacing it is just as important to keep the thing square
HTH
Post by: espen22 on 25 June 2009, 23:19:17
Sometimes they are so stuck that you need a small puller one with two arms. can be bought cheap at nearly all low price tool shops:)
Post by: feeutfo on 25 June 2009, 23:22:20
they can be stubborn if they havent been off ever/for a while. Basically deal with the bolt to spring joint bit only, as said, push down towards the screen, pull up, push down, and so on until it comes loose. And, as said, once loose hold the knuckle joint square to the shaft and will just lift away. Simples. :-)
Post by: Turk on 26 June 2009, 00:09:40
This is what you want. Works well  :y
http://www.machinemart.co.uk/shop/product/details/cht427-windscreen-wiper-arm-remover
Post by: feeutfo on 26 June 2009, 09:53:39
no tools needed guys. Honestly. Well, 13 mill socket obviously..... ;D
Post by: Teebee on 26 June 2009, 14:21:59
I actually cracked my screen taking a stuck one off (it was due for replacement anyway so maybe I wasn't as careful as I should have been) :)
