Omega Help Area => Omega General Help => Topic started by: Omega6pot on 26 June 2009, 17:16:56
Title: Can i put vented rear dics on my 00 mv6 estate?
Post by: Omega6pot on 26 June 2009, 17:16:56
Hi was wondering if i ould put the vented rear brake setup of a late facelift omega onto my 00 mv6 estate? if so does it have to come off an estate
cheers al
Title: Re: Can i put vented rear dics on my 00 mv6 estate?
Post by: Jimbob on 26 June 2009, 17:23:39
You can, doesnt need to be estate.
Not much to be gained though
Elite pete did this a while back
Post by: Elite Pete on 26 June 2009, 18:47:54
As Jimbob say's you can but there's nothing to be gained, I did it because I got a set of new genuine discs for pennys.
(http://i61.photobucket.com/albums/h64/pickledpepper/DSCF0096.jpg)
Post by: Omega6pot on 26 June 2009, 19:40:43
its more i sad kinda fetish for changing parts i have, is it just the calipers and discs you change?
Post by: Pedro on 28 June 2009, 10:47:23
To be honest, waste of time (as said) - and you'll be adding to the amount of unsprung weight.
Post by: Turk on 28 June 2009, 22:03:57
You'll upset the brake bias if you just increase the stopping power on the rear.
In an extreme case of brake bias to the rear, as opposed to the front as it should be, it would be the same as yanking up a hydraulic handbrake.
Same goes for a bike, you can put sintered pads all round or sintered on the front and standard on the rear but you cannot put sintered on the rear if the front are just standard.
Under braking, the weight of the vehicle is transfered to the front, the rear becomes lighter and the wheels require less effort to stop them turning. If the brake bias is to the rear, that now lighter rear wheel will lock up, or put the ABS system under an unneccessary and excessive workload.
Properly maintained, the standard brakes on Omegas are as much as you will ever require for any road application. :y
Post by: Elite Pete on 29 June 2009, 09:06:50
Mine was fine.
