Omega Help Area => Omega General Help => Topic started by: machornet on 29 June 2009, 12:56:50
Sounds odd, but we're stumped- where do you find the sparkplugs on a Y Reg 2.2 CDX. Can anyone help?
unplug connector on top of engine - at end of ecotec cover.
slide cover off
2 torx bolts to remove coil pack
4 sparkplugs underneath :y
As above but check for oil in the plug wells before taking the plugs out. The last thing you want is 20ml of oil in each piston causing a smoke screen ;) :y
