		Omega Help Area => Omega General Help => Topic started by: TheBoy on 29 June 2009, 10:54:17
				Anyone taken the 'Megamos' type apart - it seems to be encased in that compound used to waterproof (and IP protect) the circuit.
				1st take 1 sammy.
2nd, lift sammy over your head, and bring down on sounder (best to have removed from car at this point)
3rd, innards of sounder should now be clearly visible.
				(http://theboy.omegaowners.com/oofpics/powersounder/IMG_3997.JPG)
1st take 1 sammy.
not convinced it would :(
				weird, Ive never seen one with an oil filter sticking out the back of it before  ;D
				And yes, that is a cap and what looks like a regulator or transistor/fet poking their heads through the compound
Opps.
TB doubles checks if anything controversial in the paperwork underneath  :-[
				I've had two types apart but neither had the insides potted. Not a bad idea given the environment they're in. :-/
Are those the batteries you can see just under the surface? Just wondering if it's possible to dig them out and connect a replacement to the exposed tags?
Otherwise, a play with sammy followed by bin.  :(
Yup, they are the batteries.
I reckon my problem may be water ingress (the potting compound is cracking quite badly in places) rather than batteries themselves.
Potting compound is a complete ^!)(*&"^ pain in the backside.
I makes things retain heat, PCB's more subject to cracking, and is imposible to remove without destroying everything in its path.
Mutter, mutter, mutter ...
