Omega Help Area => Omega General Help => Topic started by: ian s on 30 June 2009, 07:40:55
Is it normal to only get 32mpg ish from one of the BMW lumps?
I think that is about right for standard spec, if you go for getting the ECU chipped then you may well see more than that. I think I usually get around 35 in town and upto 40 on a good run :y
car is chipped and my dad drives it carefully
just bunged some forte diesel treatment in it
I'm getting 32-33 round town and a run closer to 45. Been drining like an old man just to see how the fuel cons. would be and I'm up to 36 round town atm and climbing slowly.
I can only manage 33-34, and thats mostly motorway driving and national roads. I think mine needs a damn good service though
I should say so with those figures! Mines due in about 900 miles and we're off camping in Scotland in 2 1/2 weeks. 494 each way so service before we go or when we get back? I'm edging towards before to keep the MPG up in the 'tight ass' bracket ;D ;D
The damn good service must include a oil/filter change (with Vx preferably - then done every 3k) and a fuel filter change, but fill the filter with Forte or Diesel Magic before fitting.
When finished, start the motor up and hold at 1500rpm for a few minutes - take for a rag round the block for 10 minutes and that will hopefully clean the muck out of your injector pump a little bit (tip courtesy of Omegatoy)
As a rough measure of consumption I always get 500-530 out of a tank round town, and then on a run will normally get 600.
Yep that's about what I get just on local stop/start driving. Can't say it's any better consumption wise since having the chip in, but it don't half fly.
BTW I drive like an old man, cause I'm just about there anyway :P
Mick
I am driving a 2.5TD Auto I have yet to see more than 35mpg on a gentle rundown the M4 to BristolI don't want to hijack this thread so I will start another under' What needs doing on high mileage TD's'
i get about 400 miles to the tank :'( :'( but i got a lead foot ;D
Autos - 33-35mpg, manuals approach 40mpg. both less if not chipped.
i always used to get 450 - 500m from a tank from my old chipped elite td, invariably driven hard....
mine is chipped and still only about 400 to a tank cant understand it i have 198 miles done now and its just reached halfway on the gauge so i going to drive a bit steady for the other half a tank and see what happenes :y
My big test will be when we go away in a couple of weeks. Going to fill her to the brim and sit on the cruise at 75ish (M6 permitting). 494 miles according to google maps route planner so should easily do it on a tank although I'll probably fill up in Glasgow on the way through.
My 96 CDX auto estate with 203,000miles on the clock does approx 29 around town 34-35 on a run, the 2000 Elite auto estate with 130,000 miles only manages 27 around town and 31-33 on a run and does not feel as lively as the old CDX, Apart from what appears to be a slight weep from the leak off pipe I can't explain the difference. I've always been a bit disappointed with the economy and performance of the later Elite which has had regular servicing and seems to run sweetly except at a standstill in traffic, when I get an annoying vibration at tick-over. One day if I ever get time I might get the injectors checked :-[
I get a proven 33 mpg around here.
It's been chipped, and gets a fair ragging, (normally from Mrs Sethsmate!), so we're reasonably happy with this figure.
It performs very well too, especially given the terrain here!
They're reasonably good consumption figures for an auto-boxed tractor.
Change ALL the leak-off pipes, and ensure that both the fuel filter-to-fuel heater, and fuel heater-to-filter casing are securely tightened. Cured mine.
Hi im near Cambridge just now have been to Devon,New Forrest done over 1000 miles on my 2nd tank since Glasgow still have over 200 mile range left :y
ps its really warm here ;D ;D
I realy dont know how you guys get such good economy i get 22-24 max but i do drive like a nutcase ....i read somwere on here drive a TD like you just stole it
i dissconected the maff the other day to see if that made any diffrence .....made no diff at all despite the mpg i do fing it goes prety well this weeks victims include audi A4 DTI beat me off the mark but after 70 ish uphill was a diffrent story 55 reg estate 525 td bmw even stevens all the way but i was in front (ovbiously) it will cruise at a ton and the max ive had is just shy of 130 wich aint bad for an 11 year old diesel with 132k on the clock i just wish it wasent such a thirsty bitch
Its definatly female i know this because of the constant attention it requires of me ;D
Well in the garage i have oil filter, fuel filter, air filter, 2 gallons of 10/40 and a pot of diesel magic. All i need now is time. ::)
I know its desperate though, as i have had it around 2 months now, and have put 4500 miles on it and i dont know when it was last serviced. Hopefully it will be done in two weeks time, as well as a complete set of new brakes all round. Needs doing as im taking it for a short drive to Amsterdam in August ::)
Think yourself fortunate! My V6 only returned 18.5 last month :D ::)
Hmm while here in the uk im running aorund in a 1993 yes L reg
auto 2.5 td chipped ar 35 box and 172k behind it!! aircon on all the time, running to work and back which is just 5 miles from here , during the week and then longer runs at the weekend, around 200, /300 depending who i have to visit
its all low gear work in town obviously but its giving me 36.8 brim to brim same fuel station, running on esso normal diesel
going tgo try super diesel soon to see if it improves any but im reasonably happy with that figure for a sludgepump!!! :y
Manual here, driven medium hard on short runs seems to be around 35-36. Motorway 41-43 with retro-fit cruise on.. Perfectly happy with that as she pulls well even though unchipped as yet.
Serviced very well mind, including coolant changes, clean outs etc.
