Omega Help Area => Omega General Help => Topic started by: ScottieMV6 on 02 July 2009, 14:17:02
Title: Cheapo Tech 2 works advice now needed!!!!
Post by: ScottieMV6 on 02 July 2009, 14:17:02
I got my cheapo tech 2 working today and cleared the fault codes off the car.
One of them came straight back so I assume this means that the fault is still there. It is SAI related so I want to just disconnect it. I disconnected the pump under the passenger wing but the fault code is stil showing.
Can someone please tell me exactly what I need to disconnect to stop the fault code showing?  :y
Title: Re: Cheapo Tech 2 works advice now needed!!!!
Post by: TheBoy on 02 July 2009, 16:58:30
The only part of the SAI that the ECU can 'see' is the solenoid valve. Check that.
Post by: ScottieMV6 on 02 July 2009, 19:42:35
Sorry to be a dunce but what can I check on it? I have already had the wiring off it and checked for continuity. Not sure what else I can check.
A lot of people have said just disconnect everything as it is not required, but will this get rid of the fault code?
