Omega Help Area => Omega General Help => Topic started by: omegadti on 09 July 2009, 08:47:48
Title: Sunroof position disk
Post by: omegadti on 09 July 2009, 08:47:48
My sunroof keeps opening on its own despite resetting - can anyone tell me how to get to the black disc - is there a "how to" on the forum anywhere?
Title: Re: Sunroof position disk
Post by: RobG on 09 July 2009, 08:56:40
Pop out interior lamp. Remove two screws behind,pull control knob off, press tangs to remove sunroof cover. Remove the black box via 3 torx screws and disconnect multi-plugs. Unclip black box cover and you will see the black disc. Note which way it slots on to the control knob arm, remove and clean. :y
Post by: RobG on 14 July 2009, 10:01:15
If you haven`t sorted the disc yet I`ve posted a "how to" in the test zone. :y
Post by: Ghost on 14 July 2009, 10:55:30
Hope this helps you mate.
www.omegaowners.com/forum/YaBB.pl?num=1247486518
just found it in the test zone would be good to see in the maintenance guides (hint hint on the admin. ;D)
