Omega Help Area => Omega General Help => Topic started by: Lioned on 16 July 2009, 15:04:43
Title: Exhaust manifold ?
Post by: Lioned on 16 July 2009, 15:04:43
Got a 'tick' when i first start up,goes after a minute or two.Man in garage where i had MOT this pm recons probably crack in exhaust manifold recons i should just ignore it as it may cost loads to repair.
Anyone any ideas what it might cost ? Should i just not worry about it or is it likely to get a lot worse ?
Its a streight 4.   2.2lt
Title: Re: Exhaust manifold ?
Post by: Vmax on 16 July 2009, 15:09:17
It's a long job, big labour cost. I would ignore it if you can't DIY.... ::)
Post by: tunnie on 16 July 2009, 15:23:06
acess for that on 4 pots is easy, DIY it
Post by: Ghost on 16 July 2009, 15:35:51
if its the manifold it could be expensive, or it might just be that the gaskrt has blown which is not that much. either way the mani has to come off so i would stick the car on ramps and try to find the leak then you Know for sure.
Post by: Lioned on 16 July 2009, 15:53:13
Cheers,will maybe have a go myself when i'm in the mood.
