Omega Help Area => Omega General Help => Topic started by: x.ray on 18 July 2009, 12:31:35
Title: heated front seat
Post by: x.ray on 18 July 2009, 12:31:35
good morning all.
as you are all aware they do not do a haynes manual for an x reg 2.2.
therefore how do i check why my heated front seat is not working.
the passengers works fine?
cheers :'(
Title: Re: heated front seat
Post by: Agemo on 18 July 2009, 15:14:24
One fuse covers both, so if the passenger one is OK, you should look at the connection under the seat. It is possible for the elements to fail, but not likely both have failed in the same seat.  ::)
Post by: Elite Pete on 18 July 2009, 15:36:54
Its more than likely the elements but they are quite easy to replace if your seats are cloth :)
Post by: unlucky mark mv6 on 18 July 2009, 15:44:50
Ive heard the sires break on these,how do you sort that out on a leather,is it a complete strip down or what? :-/
Post by: Elite Pete on 18 July 2009, 15:46:19
The elements are sown into the leather seats so I would just push a new element between the leather and seat foam, it might take a bit longer to heat up though
Post by: unlucky mark mv6 on 18 July 2009, 15:50:38
Would really like to repair the old one,i have heard its possible if its just the sires whatever they are,i think they are the wires that run down the back or something,anyone done this as i need to fix because it irritates me knowing something doesent work on my car. ::)
Post by: Agemo on 18 July 2009, 16:11:09
Both elements going at the same time? Bit of of a coincidence but perhaps it could be.  ::)
Post by: unlucky mark mv6 on 18 July 2009, 16:13:34
Got to be the elements mate,checked the connecter at seat and got power. :-/
Post by: Andy B on 19 July 2009, 10:00:41
The base & lower back heating elements are wired up in series with other, so if one fails, you've loose both.  :y
Post by: Agemo on 19 July 2009, 13:43:27
Ahhhh, nice to know that, thanks.  :y
