Omega Help Area => Omega General Help => Topic started by: westo123 on 25 July 2009, 09:20:48
I've had a go with both the paperclip test; connected A and B and turned ignition on, no flashes and the pedal test, still no flashes.
Still the engine comes on every so often and stays on for a while.
Can anyone please tell me why?
The car is a 2000 (W) Omega Estate CD Petrol manual 2.lt and shows nothing wrong on the dashboard information display screen.
reading your thread are you saying that the paperclip test did not work or you did not get any codes?
edit - mis read your thread :-[
Don't think you can paperclip 2lt, need codes read
The paperclip test should work on a 2.0, did you have the right holes connected and was the ignition on but the engine off.
[/quote]
Don't think you can paperclip 2lt, need codes read [/quote]
That's what I thought but no one seems to know for sure.
Used A and B which I think is right and yes ignition on engine off
Used A and B which I think is right and yes ignition on engine off[/quote]
Counting from bottom of diag. plug. 3rd and 5th pins need to be bridged. :y Don`t know about A and B :-/
Counting from bottom of diag. plug. 3rd and 5th pins need to be bridged. :y Don`t know about A and B :-/[/quote]
Tried 3rd and 5th with the clip both up and down no change.
This site says A and B
http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
as does this one
http://www.makinterface.de/index_e.php3?frompage=/aldl_e.php3
I have also tried A and K.
Nothing makes any difference.
Nobody seems to have the definitive answer so
it looks like I need to get a dealer to do a tech 2 check.
as does this one
Try the REAL source of information ..
as does this one
Correct! :y :y :y
Sometimes people can't see the nose on the front of their face! ;D ;D ;D ;D ;D ;D
That was the first place I looked but it's no good as my car does not have that diagnostic plug, mine is on the drivers side and has 10 pins.
Just booked it in to be checked and the cost is only £45!!
They`re all on driver`s side on the omega ::). Like to see a pic of the plug you`re trying to `clip :-?
If the engine light has been lit, but has gone off again...?
Could it be that there simply ARE no codes stored...?
Diagnostics plug on all Omegas is the same looks wise...pin 4 and 6 on 2.5/3.0 v6's for paperclip pin 1 being top right pin then working down...not sure on 2.0
Post modified by TheBoy - I'm sick and tired of repeating the rather RULES >:(
Ok thanks for all your help so far!
Did the test again probably using the correct plug this time!!
Came up with 10 flashes,1 flash, 3 flashes, 10 flashes which I think is 0130 and relates to the o2 sensor.
Is this all correct?
Had a quick look before the wife went shopping couldn't locate it.
Can you let me know where it is and how easy it is to change?
