Omega Help Area => Omega General Help => Topic started by: davyd269 on 30 July 2009, 19:40:13
Title: oil warning light
Post by: davyd269 on 30 July 2009, 19:40:13
i know the car im picking up on sunday has a problem with the oil warning light flashing on every now and then even though the oil level is spot on is this a common fault is it gonna be something big or expensive or is it an easy fix with a nex sensor any help would be more than welcome thanks
Title: Re: oil warning light
Post by: Andy B on 30 July 2009, 19:46:40
when you say 'oil warning' do you mean the level sensor which would give a message on the dispaly along the lines of lack of oil, or do you mean low pressure light. If it's lack of pressure it could be anything!  :-?  :y  :y
Post by: davyd269 on 30 July 2009, 19:49:11
ha ha good point not sure yet but im sure ill be baco on here on sunday
Post by: billy no mates on 31 July 2009, 11:42:14
Had the same problem, changed the oil pressure switch all OK now. Got genuine from VX as cheaper than aftermarket only about £5.
Post by: vauxsull on 01 August 2009, 16:47:10
I too get the "check oil level" on a regular basis every 1k or so but when I check it all appears ok. no oil leaks at all so do I have a dodgy sensor somewhere?
