Omega Help Area => Omega General Help => Topic started by: Miggy24 on 26 July 2009, 15:24:58
Hi all mysunroof is leaking and has made the pass seat wet.Its leaking from the front left coner can anyone help me to sort this even if its temp
I think the way it works is:- All sunroofs are prone to leak, so the manufacturers fit drains, so it does sound like yours is blocked. Not sure where the drain is on an Omega, but it is worth finding it & giving it a good "Proddling" with a bit of curtain wire.
It's a blocked drain(s)
You will find a small hole in the front corners of the roof frame
Gently probe with a piece of plastic covered wire as used with net curtains
Do not be rough with your probing as you may dislodge the pipes that run down to under the wings
You will know when clear as water will run out onto the road
Cheers guys.I just used abit of mig wire down the little holes so now only time will tell
And the rear ;), you can see where the pipes go through the boot floor near the petrol cap release motor & at the front of the spare wheel well. :y :y
Just went and had alook to see if its still leaking and is it.Can you think of anything else
As said, the seal on the sunroof isn't water tight, it's a felt/fabric isn't it - & I ain't going out to check, it's dark ;) - and any water that gets passed it is designed to drain to the floor via the 4 tubes, one in each corner.
Your drain tubes are still blocked. I doubt if MIG wire will shift the blockages and you run the risk of it puncturing the plastic drain tubes. As suggested earlier, use curtain wire.
Hi all well iv done what was said and it still leaked so i thought i would just seal it up.Since iv done that its been fine but today its leaking again and its starting to really pi** me off as its starting to make the car smell.Can anyone think where it can be coming from
