Omega Help Area => Omega General Help => Topic started by: L3M on 15 July 2009, 01:42:38
Title: Auto stalling and hunting when stopped
Post by: L3M on 15 July 2009, 01:42:38
Hi all, first off, I'm new to the forum and have just bought a 2.0l 2000 W plate omega cdx estate and it seems to have a curious fault on the auto box. Starts fine and drives fine but once you stop it either idles fine (approx. 800rpm) for 30 seconds or so and then dies without warning or the revs start hunting (approx. 900 - 1400rpm) and then dies. Doesn't seem to matter whether it's in D, N or P and it sometimes feels like it doesn't really want to disengage gear when shifting from D to N or P.
Any thoughts, help or advice would be much appreciated,
Cheers,
Doug.
Title: Re: Auto stalling and hunting when stopped
Post by: dbug on 15 July 2009, 02:10:55
Check atf fluid level in box.  Whats the mileage? - may need to change fluid dependant on mileage/fluid condition.
Post by: L3M on 16 July 2009, 00:45:21
Hi, mileage is 150,000 will check atf fluid level or maybe just flush and replace and then report back if problem persists. Does the auto box on these have a "sump like" drain plug and a side/top mounted plug for filling i.e. when full the atf fluid leaks back out of filling hole?
Post by: Pete Elite on 16 July 2009, 01:23:21
  No drain plug just a filler/check plug.
 When you say it idles roughly it could be the idle control valve(ICV)needs cleaning, do you know when it was last done :question.
Post by: spikerz on 16 July 2009, 01:28:33
these should help for gear oil check/change.
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
http://www.cavweb-forums.co.uk/showthread.php?t=62232
Post by: sladey1985 on 16 July 2009, 02:49:54
hi mate what do you clean the icv with...?
Post by: Pete Elite on 16 July 2009, 03:17:20
   Carb cleaner, let it dry and then oil the valve with some 3in1 :y
Post by: sladey1985 on 16 July 2009, 03:33:24
hi thanks for replying when you say 3in1 is it the same as wd40..?
Post by: L3M on 17 July 2009, 20:46:31
just out of interest, where would I find the ICV and what does it look like?
Post by: Pete Elite on 18 July 2009, 01:14:54
  I don't know where it is on a 2.0L as I've a V6 but it looks like this :y.
 As for using WD40, it's not really a suitable lubricant so best use a light oil such as 3in1 :y.
(http://i140.photobucket.com/albums/r2/Omega1958/05_1_b.jpg)
Post by: Auto Addict on 19 July 2009, 08:09:21
Full instuctions are in the 'Maintenance Guides'
Post by: L3M on 05 August 2009, 05:15:26
Big thanks to everyone on the forum for their replies and input, took the car for service and gearbox top-up which didn't cure the problem, took car back and had the ICV and throttle position sensors cleaned and serviced and everything is all good with the car again and no more stalling.
Post by: Pete Elite on 05 August 2009, 16:25:32
          Glad to here you got it sorted :y.
