Chat Area => General Discussion Area => Topic started by: Varche on 01 December 2007, 12:56:09
Title: Differences between 3 litre and 2.5 engine
Post by: Varche on 01 December 2007, 12:56:09
Just an idle thought but is it possible to rebuild a 2.5 as a 3 litre?
Is the extra capacity from a different crank or bigger pistons? I know the cams are different on the three litre. What else don't they share?
varche
Title: Re: Differences between 3 litre and 2.5 engine
Post by: JamesV6CDX on 01 December 2007, 12:58:08
You'd need a different block and heads. So essentially a new engine!
Ancilliaries Im sure are all the same.
Post by: Kevin Wood on 01 December 2007, 13:56:54
As James said, I think bore and stroke are different so practically all engine main components (block, heads, crank, rods, pistons, cams) will be different.
Best to start with the right engine.  :y
Post by: TheBoy on 01 December 2007, 15:17:23
block, pistons, crank, heads, cams, valves. probably more...
Post by: Andy B on 02 December 2007, 22:53:24
Apart from them .... they're nearly the same!!!!!!!  ;D ;D ;D
